If you have a TSP 228r cam, I want your opinion
I ve been running it for 6 months it pulls hard. shoulda went bigger. Do the 112 LSA its fairly smooth after start up...wish it was choppier. 228R on a 112 great for the DD. Id go one bigger than what your thinking.. I went 228 because I was thinking 224 and still should went with a torquer or something but im not dissapointed just hind-sights 20/20. Tho Im sure with a set of heads it will be a world of difference...im just not there yet.
The following users liked this post:
Qdttracer9 (01-24-2021)
since i got a lot of pms about the dyno sheet and idle vid here it is:
![](http://img5.glowfoto.com/images/2008/12/28-1709487500T.jpg)
http://www.youtube.com/watch?v=HgVl8V7E43E
#33
I like my 228 cam on a 112. My only complaint is it hits like a freight train at 3500rpms and pulls hard right up to the limiter at 6700 rpm. I wish it wasn't as peaky. I went with some 4.10's and they really complimented the cam too. I am adding a fast90 and some afr's this spring (ls6 intake and ported stock TB right now) but I don't think it will change the cam much, just add some more power/tq all over the curve. With a proper tune this cam makes a great daily driver IMO.
#34
I like my 228 cam on a 112. My only complaint is it hits like a freight train at 3500rpms and pulls hard right up to the limiter at 6700 rpm. I wish it wasn't as peaky. I am adding a fast90 and some afr's this spring but I don't think it will change the cam much, just add some more power/tq all over the curve. With a proper tune this cam makes a great daily driver IMO.
#35
7.40 but my motor isn't yours. Best advise is buy a pushrod length checker or find a buddy with one. If you are on stock heads a 7.40 should work but the key word is "should". I can't put anything together if someone on the internet says the word "should". Thats why I suggest a pushrod length checker
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#36
the 228r carried my truck with LS1 down the track to a 12.66 with a 1.73 60' and a mail order tune. other mods were ls6 intake, p&p TB, underdrive pulley, lt's, 3800 stall, 4.10's, CAI
#37
Def go with the 228R on a 112. I was recommended by comp to go 7.425 due to the cam being a slighly smaller bore or w/e than stock cam and the valvetrain is slightly quieter than most with 7.4
#39
LS1Tech Premium Sponsor
We've done 228R installs replacing the 224 camshaft & seen 7rwhp gain. For the durations we're talking I'd take the 228R over the 224 duration camshafts without a doubt. The 228R drives just about identical to the 224 camshafts & made more power starting at a very early rpm.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
#40
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
few videos of 288r.. havent got tuned yet, but have most of bolts on. Even without a tune, is drivable.. plan on tune in the spring. but i like it, just waiting for some 5.3 heads
LS1 2000 Camaro z28 TSP 228R cam start-up
LS1 2000 Camaro z28 TSP 228R 112 lsa cam idle
2000 camaro z28 ls1 walkaround
camaro ls1 z28 backout garage
