Valley Cover
Old Dec 29, 2008 | 04:12 PM
onebadredss's Avatar
Default Valley Cover
Well i got a free Valley cover from a friend its the LS6 Valley cover and i was looking at the bottom and was wondering what kind of seal goes under the valley cover... is it the same as the ls1 and is it reuseable... does anyone have pics 2?
Old Dec 29, 2008 | 04:16 PM
DONAIMIAN's Avatar
Uses the same gasket. Weather or not to replace it depends on the condition.
Old Dec 29, 2008 | 04:22 PM
bowtiekid's Avatar
LSx gaskets are meant to be replaced after they have been torqued down and loosened. So IMO grab a new gasket and dont worry about it later.
Old Dec 29, 2008 | 06:23 PM
First Collision's Avatar
Actually most of them are meant to be reusable.. all depends on the condition though. Might as well replace it while its off.
Old Dec 29, 2008 | 09:28 PM
bowtiekid's Avatar
A few times maybe. but my book states not to..
Old Dec 30, 2008 | 10:49 AM
hmm i just know that most of those gaskets are the ones you embed into the valve cover for example well i looked under the valley cover and there is no line where you can push the gasket and i think there isnt one of the block either.. if i make sense..
Old Dec 30, 2008 | 12:06 PM
Damian's Avatar
LSX Mechanic
Keep in mind, to put an LS6 valley cover on an LS1 engine you will need to do some grinding. There is a tab or "boss" in the valley that has to be ground down about 1 inch deep, by 1/2 inch depth.
It's worth it however. You can completely delete the POS pcv system.
Old Dec 31, 2008 | 12:38 AM
ss69's Avatar
Haha you beat me to it. There is a gasket to use. I got one with my LS6 valley cover and I got one with my gasket kit.
