5.3L Question.
Old Dec 30, 2008 | 02:49 AM
1FastBrick's Avatar
Originally Posted by the_merv
You are going to have to drill and tap the Iron Block for the Alternator Bracket.
Intresting... I did not know this... are there any threads out there with pictures or a how to???
Thanks for the heads up!
Old Dec 30, 2008 | 02:58 AM
the_merv's Avatar
I have a pic of mine where I drilled for it.
Here is the bare block..
And here is a pic where you can see where I had to Drill & Tap the flange on the Drivers Side of the Block to mount the Alternator Bracket.
Old Dec 30, 2008 | 03:12 AM
davidhouston23's Avatar
There's a 5.3L aluminum block as well correct? Would I have to drill that one as well?
Old Dec 30, 2008 | 03:17 AM
aksz71's Avatar
correct... 1fastbrick- its a miracle ppl actually putting a 5.3 in something besides the throw in a 6.0 haha
Old Dec 30, 2008 | 10:11 AM
1FastBrick's Avatar
Apparently not. I found some pictures of the front of the block on Ebay and it apears they are already drilled. From what I have found its a gen 4 platform There are a few differences from gen 3 to gen 4 plate form. Mechanicals are basically the same. how ever the moved some of the sensors around on. the knock sensors went from the top to the side of the block. I believe the cam sensor went from the top back to the front of the timing chain cover. ant I think they went from a 24x to a 48x reluctor wheel on the crank. Its basicaly a small bore LS2 motor
You can still run this engine with your wiring harness and computer but you will need a few extension harnesses sold through one of our sponsers. and for the cranks sensor you need a step down box. I believe LPE is the only one who makes that.
Old Dec 30, 2008 | 10:52 AM
the_merv's Avatar
Yea, that is a Gen IV Block, mine is still a Gen III, that is why I had to do it.
