cam choice, what cam do u recomend?
Old Jan 3, 2009 | 10:52 PM
caviness's Avatar
i have your cam for sale ready for you brand new in box
https://ls1tech.com/forums/lsx-parts...-needs-go.html
Old Jan 4, 2009 | 01:32 AM
2001ws6-500hp's Avatar
do u know the specs on it?
Old Jan 4, 2009 | 01:35 AM
nvmd, look at the pic dumbass. my bad
Old Jan 4, 2009 | 01:38 AM
Trans Am Jam's Avatar
for a DD like yours I recommend the TR224
Old Jan 4, 2009 | 07:28 AM
caviness's Avatar
tr224/564/110+0
Old Jan 4, 2009 | 09:23 AM
PREDATOR-Z's Avatar
Originally Posted by 99blancoSS
Since when does budget have anything to do with a cam choice?
It will cost him double if he stuffs a stupid big cam in there and hates driving his car and only has to change it out.
I almost passed out when I saw Pred recommend the TR224.
One thing though, you dont need to change locks with stock retainers.
The PAC springs are true drop in replacements. You re-use your OEM retainers and so the locks go with them.
Sticking around the TR224 or 224/228 is good way to go. You'll have plenty of power under the curve (more usable form). Bigger cams move the power band up and not every one likes having to keep the rpms in the upper range to pass someone. Bigger cams make more power up top and unless your rpms are up top your are not utilizing that power. Gas consumption goes way up as well. There are trade offs. Yes the bigger cams pull like a freight train once you hit their sweet spot but the power getting to that point is quite unimpressive and in some cases just plain poor.
Blanco,
Get the smelling sauce ready
I never had anything against TR224, but I can still spec a 224/224 that will make more power than that cam everywhere, using new lobe tech and slightly different VEs.
Idealy (doing it right); locks should be changed unless you can put them back in exactly in the same position they came out. Why? because they will bear an individual imprint mark from their previous position. So for the price they cost, virgin locks are a better choice.
Old Jan 4, 2009 | 01:30 PM
99blancoSS's Avatar
unconscious now...LOL
Well we've never seen an issue with re-using locks but I do like the safety factor of new ones Good point, for the cost of them it certainly doesnt hurt
Old Jan 5, 2009 | 11:17 PM
HTX's Avatar
HTX
Originally Posted by PREDATOR-Z
Blanco,
just out of curiosity... how would you spec a 224? similar to the now famous elorro??
I ask because i amcurious how an XFI on a 224 would would work... with maybe something less than 112lsa
Old Jan 6, 2009 | 12:38 AM
Nitroused383's Avatar
Here you go, he just speced one for me the other day. 224/224 .609/.581 111+2 LSA xfi/xer. Thanks alot too I still dont know what I want to run for a cam lol.
Old Jan 6, 2009 | 07:13 PM
nmcqueen469's Avatar
OP, make sure if you are an AUTO you factor in the cost of a good stall converter also.
Old Jan 8, 2009 | 01:43 AM
thanks and good point wht would size be reccomended for a DD
Old Jan 8, 2009 | 01:57 AM
  #32
and will the tr224 give me that nice sound?
Old Jan 8, 2009 | 10:27 AM
  #33
01ssreda4's Avatar
my tr224-114 has a nice subtle idle. with turndowns (its loud) you can hear the lope but its not super aggressive. you can tell its cammed bc the idle is not smooth like stock.
Old Jan 8, 2009 | 03:00 PM
  #34
99blancoSS's Avatar
X2
I had people at traffic lights tell me they knew it was cammed and sounded great. Its not a huge popcorn sounding pronounced lope but it has a subtle rhythm to it.
Old Jan 11, 2009 | 07:41 AM
  #35
Tommyv8's Avatar
3000-3400ish
Old Jan 11, 2009 | 10:48 AM
  #36
SOMbitch's Avatar
thanks and good point wht would size (stall) be reccomended for a DD
Pick a cam first and match your stall to it. Need to know gears too. We'll assume your stock weight and not on a diet.
Lot of things determine correct stall.....
Old Jan 11, 2009 | 01:12 PM
  #37
chrs1313's Avatar
Originally Posted by Tommyv8
3000-3400ish
no at least a 3600 for a cam only car...
i would recommend a 4000 for anyone getting a cam
Old Jan 11, 2009 | 02:15 PM
  #38
hawk18's Avatar
Default cam
be hard to get that horsep with out spray.with what you want
Old Jan 12, 2009 | 12:31 AM
  #39
3.23s in the rear end. full weight thanks for all the input. my headers and y pipe are goin this weekend. i think im settlin on the tr224 at 112, ls6 springs, new locks and new push rods. would i have to keep the same size pushrods are get longer ones?
Old Jan 12, 2009 | 01:33 AM
  #40
You will want better springs and pushrods. Comp 918's would probably work just fine for you. I'm not sure if you will need a longer pushrod or not but you will definitely want stronger pushrods.
