TSP 231/237 or TR 230/224
Here is a link to full story with mods:
http://www.fastls1.com/forums/showth...;threadid=2279
i've also heard good things about the tsp231/237 but do not have any first hand experience with it. from what i've seen, it seems to be a little bit more of a peaky cam without as good of torque curve. however, if you ever plan on spraying your car then that cam would be a good choice.
with either cam you will need to upgrade your valvetrain parts. you will need new springs to handle the extra lift. this may require that you buy new retainers, seats, and valve seals depending on which springs you choose. you will also need hardened pushrods. that is all that is required that you upgrade, however, i would suggest upgrading your timing chain as well. good luck with whatever you decide to go with.
Should I go TSP 231 and save myslef a future swap to go bigger? My car is a daily driver. Would the benefits of the TSP 231 be seen strictly at extreme revs?
Ah, such dilemmas....
Heads are planned for next year. I want this to be my final cam swap. The C1 was great, but I want more already!
