Valves hit pistons - Questions
Old Jan 7, 2009 | 10:39 PM
6.0monsta's Avatar
Default Valves hit pistons - Questions
LS2 -
Timing chain broke and caused the valves to hit the pistons. A couple of the pistons are hit hard enough to feel the roughness of metal sticking up a little.
1) When the valves hit the pistons are the pistons ok to reuse? Can/should they be machined or grinded down?
2) When the valves hit the pistons does it send a shock through the crank and or bearings that would cause a concern for reusing it?
Plan is to buy a set of TFS heads and bolt it to the existing block. Just want to make sure the cam/pistons/crank, etc are ok to reuse.
Old Jan 7, 2009 | 10:42 PM
5.3LJimmy's Avatar
I would say you are okay to reuse everything. You can sand down any sharp points on the pistons to make sure you don't have hot spots.
Old Jan 7, 2009 | 11:22 PM
zx9rgreen's Avatar
Originally Posted by 6.0monsta
LS2 -
I'm interested in what kind of chain broke and the circumstances that caused the failure
Old Jan 8, 2009 | 09:05 PM
405HP_Z06's Avatar
Sounds similar to this thread. You should read through it:
https://ls1tech.com/forums/generatio...n-failure.html
Old Jan 8, 2009 | 09:18 PM
jay_lt4's Avatar
tell us more about your engine, did you have a underdrive pulley??
Old Jan 8, 2009 | 10:02 PM
SOMbitch's Avatar
Ghetto flycut Now you are ready to clear that Texas Giant
Seems like several GenIV engines recently have busted TC's under suspicious circumstances running UD pulleys.
However, you should be fine if you lightly take the sharp edges off the piston eyebrows. Valves will bend before rods so I think you are ok there. So clean'em up, throw those TFS on there with a nice cam and go have some fun. Pics of the carnage would be NICE though
After reading about this I would definitely go back to a OEM balancer or better get an ATI Super Damper. They have a 10% UD and heard they just released a 25% UD not even in thir catalog yet. Those and maybe a March would be the ONLY ones I would consider. Beat on it hard and ATI is the ONLY choice I think. I guess there is a good reason so many in NASCAR run them
Sounds like you were lucky and making the best out of a tough break
GOOD LUCK
Old Jan 9, 2009 | 05:17 PM
lsxmalibu's Avatar
looks like he may have had an aftermarket pulley
https://ls1tech.com/forums/lsx-parts...nk-pulley.html
Old Jan 9, 2009 | 06:13 PM
RyderTA's Avatar
Also interested in your specific mods, possibly an ASP pulley?
Old Jan 9, 2009 | 06:22 PM
KCFormula's Avatar
What was your VS seat pressure?
