99 LS1 Push Rod Question
Old Jan 9, 2009 | 10:34 AM
sujomatt's Avatar
Default 99 LS1 Push Rod Question
I have a 99 Z28, swapping to a LS6 Cam shaft and Springs.
Since I am swapping heads as well - I figured upgrading the pushrods would be nice since I am going FI.
My question is - What size pushrods would I need? It looks like both LS1 and LS6 require the 7.400" Pushrods. Can anyone confirm? And also what width would I need? I saw 5/16" and I think 3/8".. Thanks!
Old Jan 9, 2009 | 11:16 AM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
As long as your heads are not milled you should be able to use the 7.400" length, and 5/16" is the correct width for the LS1s.
Old Jan 9, 2009 | 11:39 AM
sujomatt's Avatar
Thank you!
Old Jan 9, 2009 | 12:20 PM
BAD2000TA's Avatar
I believe that the base circle on the LS6 cam is slightly smaller compared to the LS1 cam. Might want to investigate further. 7.425" might be your better choice, as it will likely reduce the valvetrain noise. Check before you order.
Old Jan 9, 2009 | 12:39 PM
sujomatt's Avatar
To clarify - i am installing unmilled 317 heads.
Old Jan 9, 2009 | 01:18 PM
litle88's Avatar
Yes the Base circle of the Ls6 cam is smaller so you should need a LONGER pushrod!
Old Jan 9, 2009 | 01:21 PM
sujomatt's Avatar
So the best choice is in fact 7.425"?
Just wanted to get more feedback before I order.
Thanks
Old Jan 9, 2009 | 03:48 PM
ss.slp.ls1's Avatar
Yeah. And as always, you should use an adjustable pushrod to verify the valve train geometry, don't guess.
Old Jan 10, 2009 | 12:01 PM
sujomatt's Avatar
ty all
Old Jan 10, 2009 | 01:13 PM
01ssreda4's Avatar
agreed, i think most are the same. 7.4s tend to be a bit noisier and 7.425s seem to be quieter from what i have read.
Old Jan 14, 2009 | 10:50 AM
sujomatt's Avatar
awesome, will b ordering those 7.425" pushrods. Thanks!
Old Jan 21, 2009 | 11:28 AM
sujomatt's Avatar
BUMP - forgot to tell you all that i am going to be using 317 Heads... What length with those? Any difference??? Thanks..
