cracked block... :(
Old Jan 9, 2009 | 06:00 PM
cellulis44's Avatar
Default cracked block... :(
Well, getting everything buttoned up and I noticed this:
right where the damn water pump bolts on... drivers side, lower port...
should I even worry about it? doesnt look like it will effect the structure or sealing of the block..
just figured I'd ask.
Old Jan 9, 2009 | 06:08 PM
LS199CAMAROZ28's Avatar
if it was mine i'd just put a little black silicone on the gasket. shouldn't affect the strength of the block, but it may leak.
Old Jan 9, 2009 | 06:09 PM
RyderTA's Avatar
Hard to tell from the pic, but that doesn't look cracked to me, looks more like a scratch imo. It doesn't look very deep either, i'd think you would be ok...
Old Jan 9, 2009 | 06:59 PM
blackLS1m6's Avatar
I guess you will have to see what happens, did it leak before you tore it down? If it didn't i wouldn't worry about it.
Old Jan 9, 2009 | 07:28 PM
LS1MCSS's Avatar
That's not a crack. It's a casting line.
Old Jan 9, 2009 | 07:58 PM
LS1_K1DD's Avatar
Doesn't look like much of a crack, dont worry bout it!
Old Jan 9, 2009 | 08:28 PM
NEMESISVETTE's Avatar
I will buy said cracked block for $2.37.... What say you? LOL thats a casting line bro, not a crack. YOur good to blow.
Old Jan 9, 2009 | 08:55 PM
cellulis44's Avatar
well thanks... I JB welded it for no reason then.
Block is still for sale for $3000 though
