Parts for Head/Cam swap?
Old Jan 13, 2009 | 12:48 PM
darknessxyz's Avatar
Default Parts for Head/Cam swap?
I'm planning to do the head/cam swap by this summer. I try to gather everything I need so I don't have to do the job twice. If there's anything else recommended or mandotary to replace, please post and let me know.
So far I've these parts ready:
Cam/Head (Of course)
7.425 push rod
LS2 Timing chain (maybe go for Rollmaster adjustable)
LS6 Oil pump ported
Water pump
Front cover gasket set
...and what else I need or recommended? Should I do the lifter?
Thanx
Old Jan 13, 2009 | 12:58 PM
383lt1impala's Avatar
Spark plugs all the fluids, lifters, front main seal. Balencer bolt, new or arp head bolts.
Old Jan 13, 2009 | 01:43 PM
Adam1982's Avatar
head gasket, oil pump O-ring, maybe new lifter trays
Old Jan 13, 2009 | 02:45 PM
Jon@Texas-Speed's Avatar
Assuming the the heads come with springs, I think you will just need a heads/cam gasket kit (head bolts and gasket, front cover gasket, crank seal, water pump gaskets, and balancer bolt.) and an oil pump o-ring. We have a N-motion single roller chain that is adjustable and reasonably priced. Other than that, you will be good to go! Let us know if we can help at all!
Jon
Old Jan 13, 2009 | 02:51 PM
DoubleTapDrew's Avatar
Here's my list (I'm doing it soon also) along with GM part numbers (it was in excel so the columns no longer line up), and quantity needed. Also I have a 98, hence the coil brackets.
Heads P/N Qty
V-Cover gasket 12560696 2
Coil Brackets 12563288 2
Head gaskets (pair) 12498544 1
Head bolt kit (1 head) 12498545 2
Valve Cover Bolts
Cam
ls7 lifter set (set of 16) 12499225 1
LS2 timing chain 12586482 1
Timing cover gasket 12558013 1
LS6 Intake
Valley cover gasket 12558178 1
Headers
Header Gasket 12617944 2
Oil Pump
Water pump
WP gaskets 12559271 2
Old Jan 13, 2009 | 03:17 PM
Forget to mention I've a new 25% balancer pulley and new GM bolt goes with the install.
LS7 lifter or Comp OE-R lifter?
Old Jan 13, 2009 | 03:21 PM
SOMbitch's Avatar
Yes do lifters and lifter trays are only about $32 a set do the LS2 trays. They are a little sturdier than the LS1 trays.
Old Jan 14, 2009 | 05:55 AM
Anyone know the part number for GM MLS gasket (stock thickness) and LS2 lifter tray?
Old Jan 14, 2009 | 06:20 AM
'02 WS6's Avatar
Agreeing with the others, YES get lifters and trays. LS7 is what I would get but there are also Caddy race lifters and Comps. Have you thought about going with cometic gaskets opposed to gm mls?
BTW for conversational purposes, which H/C combo did you go with?
Old Jan 14, 2009 | 07:17 AM
I got a nice deal on some Comp OE-R lifter (Thanx Lawnboy), even cheaper than LS7 lifter from GMPD so I just go with that. I've think about Cometic. Most likely I'll run stock thickness so if GM MLS is cheaper, I'll just go with that. I need to ask the cam experts (Predator-Z and Pat G) some questions about the head gasket thickness on my setup. So we'll see.
I'll be running TSP 224R with custom port 5.3L head mill to 61cc. It'll be running 11.2:1 so that's the reason why I'll running stock thickness head gasket most likely.
Old Jan 14, 2009 | 09:21 PM
So anyone know the part number for GM MLS gasket (stock thickness) and LS2 lifter tray?
Old Jan 14, 2009 | 09:31 PM
formula4437's Avatar
depending on your setup new injectors
Old Jan 14, 2009 | 11:25 PM
The PN listed above is the GM MLS gasket 12498544. It comes as a pair so you just need to order one. They run about $30. I'm not at work so I can't look up the PN for the lifter trays right now.
Old Jan 15, 2009 | 01:33 AM
Oh yea injector, I almost forget. How much # injector I should got? Maybe a Walbro 225 as well.
DoubleTapDrew, when you back to work, can you pull the PN for the lifter tray.
Old Jan 16, 2009 | 10:51 AM
Havok2's Avatar
Originally Posted by darknessxyz
doubletapdrew, when you back to work, can you pull the pn for the lifter tray.
12595365
Old Jan 27, 2009 | 02:07 PM
Originally Posted by Havok2
12595365
Can someone at work check this part number, are they LS1 or LS2?
I need LS2 lifter tray part number
Old Feb 5, 2009 | 06:37 PM
That's the LS2 PN
Old Feb 16, 2009 | 07:20 PM
1Loudz28's Avatar
bump for jasons thread and
whats the part number for a crank/front main seal ?? thanks
Old Mar 20, 2009 | 02:31 AM
Anyone knows?
Old Mar 20, 2009 | 02:37 AM
airmaxon1's Avatar
Anyone knows?
12585673, i believe
