pistons for 408???
im going for a good N/A power this year and im using these
http://store.summitracing.com/partde...0&autoview=sku
heads. next year ill be spraying a 350+ direct port, so i need something thats going to be nitrous friendly. i dont know what comp ratio to run, since ill be spraying such a large shot. i just know ill be running thoes heads, on a 408 with probably a TSP texas Giant this year, and next year run a custom nitrous cam.
depending on situation sometimes use wiseco cause their shelf piston C/D works better for a decked block, out of the box.
Wiseco is in the middle of moving all their shelf sets over to using GFX rings, they will cost more, its a better ring, napier 2nd ring.
If I need a 4.040" piston with a 1.100" CD i'll use Diamond, Eric there can get out a custom set quicker.
you can't go wrong with either brand
Well, we need to know what rod you plan on running (length). Has teh block been decked? Used or new block? You know history of the block? I am assuming a 4" crank and 4.030 over 6.0 truck block is gonna be your setup? A DD? Street only car? Strip only car? Both? Weekend warrior? What? I ask, as that would determine compression (for the most part) or how much compression you can get away with anyways (race gas or pump)
need more info
the block will be zero decked when the pistons and rods are chosen. the block im getting is used, and as far as i know it hasent been decked. ill have the machine shop check it out when i get it. it is a 04 6.0 iron block, unless the deal falls thru, ill be looking for another one.
its going to be a race car that is driven on the street. i.e. if im feelin froggy, ill take it out for a cruise. otherwise ill probably want to drive it to the track ~an hour drive or so, and maybe take it on a road trip this summer. so i'd like it to be somewhat streetable. but most of its life will be on the track. this is part of the reason i decided to go with a 408, because a max effort 346 is not very street friendly and i can get better performance out of this and it will still have street manners.
next year, i plan to spray it with a 350-400hp direct port kit, so i would like to prepare for that now. i talked to the guy at TEA and he suggested the "as cast" 220 TFS heads for my budget now, and next year, bring them back (i only live 2 hrs from TEA) and he will CNC them for a small fee.
im looking to have a bullet proof bottom end with eagle crank and rods, i just need to know what pistons to run with them. im not exactly sure what CR i need to go with because of the nitrous.
i would like to have 500+RWHP N/A and around 850 on the sauce.
i already have a 9 inch rearend with 4.11 gears with a chromemoly driveshaft, and i will be rebuilding the T56 to handle around 900 hp to be on the safe side of life. LMK if there is anything else specificly you need to know. i want to have all these plans layed out before i go buying parts that dont match up.
Picture:
I'm building pretty much what you want to build right now. Check the link to my Formula in my sig. The last page outlines everything I'm working on and all of the parts I'm using.
Use this and plug in numbers.
http://www.csgnetwork.com/compcalc.html
If you shop around you can really find good deals on here. What you got seems like a nice deal depending on what material the pistons are, their specs, and what type the crank / rods are. Good job.
