Freshly built ls1 knocks
Old Jan 20, 2009 | 07:45 AM
Old Geezer's Avatar
Default TAC module
Originally Posted by chevrev
After doing some research, it appears that the 1518 code is related to the TAC module...isn't that only used for DBW throttle bodies? I am using a cable driven (non-electronic) t-body.
Could my PCM be programmed for a DBW setup? Could this be why the engine bogs down and won't rev?
With DBW, the TPS signal comes from the throttle actuation motor. It communicates w/ the PCM, thru the TAC module.
If you have a cable setup, and a DBW program, the PCM is not getting a TPS signal. Thus no accel enrichment. That = lean/knock possibilities.
B4 I went further, I'd take a look at the PCM w/ a tuner. [IE: EfiLive]
PS: Just looked at my EFILIVE.. I see 15 PIDS referring to the DBW.
