Timing Chain Dampner 6.0
LS1Tech Premium Sponsor
It will work on some...to check, look at the front main journal right above the crankshaft...if it has two holes centered above the crank, that's the two holes for that dampner. If the holes are not there, it wasn't meant to be
There's an image (with my awesome MS Paint skills) that shows in green where the two holes will be.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Actual pictures here.
__________________
