degreeing cam: is it necessary?
Old Feb 12, 2003 | 10:33 PM
SlammedSS02's Avatar
Default degreeing cam: is it necessary?
The guy that is installing my cam asked me if I want him to degree it or not. My question is with a TR227/224 with 114lsa or any other cam for that matter, what is the purpose? Are there any benefits from doing this or is there nothing really to be gained from this? Any input would be appreciated and I really need to know by Friday.
Old Feb 13, 2003 | 02:53 AM
smokin' joe 00 ss's Avatar
Default Re: degreeing cam: is it necessary?
Yes have him degree it, some people just throw them in dot to dot but it's a good practice to degree it to make sure the grind is were the cam card says it is.
Old Feb 13, 2003 | 07:35 AM
Biochem's Avatar
Peace of mind mostly... as long as your clearences are OK, there is no absolute need to degree the cam. But since it takes all of 5 minutes to do, why not?
Old Feb 13, 2003 | 05:11 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by jmX:
<strong> Thunder racing already checks all cams on a cam doctor so its not really going to serve any purpose. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I know, I know but any pro engine builder will tell you to always degree the cam to make sure the install is done right and and the grind is right even if you think the cam has been on the doctor since there has been human error's in packing of cam's and cam card's before.
Old Feb 14, 2003 | 12:29 AM
jmX's Avatar
jmX
Old Feb 14, 2003 | 05:19 AM
Raughammer's Avatar
D(irecto)r Pepper
Degreeing protects you many ways.
Makes sure the cam is installed as per the manufactuer...and make sure the cam was ground as per your orders.
Makes sure the timing chain installed correctly as per the cam.
etc. etc. etc.
I "ALWAYS" degree them.
It's just good practice.
Old Feb 14, 2003 | 09:33 AM
2000SSNB's Avatar
I there a way to accurately degree in the cam WITHOUT the cylinder heads off? I would like to do this but don't want to take the heads off for the job.
Thanks,
Gert
Old Feb 17, 2003 | 08:22 AM
horsepower's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 2000SSNB:
<strong> I there a way to accurately degree in the cam WITHOUT the cylinder heads off? I would like to do this but don't want to take the heads off for the job.
Thanks,
Gert </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Replace the valve springs with a tester spring - this way the lifter wont compress.
I would recommend ALWAYS degreeing the camshaft. Why rely on the grinder operator to get the index correct? If you are installing a custom ground cam, aftermarket timing chain, aftermarket crank, (ie anything that may impact cam timing) it is plain stupid not to degree it. If you put that kind of $$$ and effort into your engine, do it right <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Plus, performance drops-off in a hurry as you move away from a proper ICL <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
-brian
