Failures of stock lifters??
Old Oct 3, 2003 | 09:29 PM
Redline-Motorsports's Avatar
Default Failures of stock lifters??
Just wondering about any history of failures of stock lifters. We had a problem while pulling a motor on the dyno the other day and it sounds like a lifter let loose. I am taking the head off tomorrow but was looking for a little insist from anyone that has had issues. I have found the stock lifters to typically be VERY reliable and never had had a problem with modified motors.
Old Oct 4, 2003 | 12:38 AM
Z-Rated's Avatar
Default Re: Failures of stock lifters??
In what year car? I was told that there is a difference in years, something like the support is weaker with the new ones?? I really cant think of much more than that... I was talking with Colonel, im sure he remembers
Old Oct 4, 2003 | 12:44 AM
onyxxtreme's Avatar
so are aftermarket lifters absolutely preferred with a really strong valvetrain?
Old Oct 4, 2003 | 02:45 AM
Raughammer's Avatar
D(irecto)r Pepper
I have always used the stock ones in ALL my motors.
Get a good lite valve train and top of the line springs. Your good to go. (IMO)
Old Oct 4, 2003 | 05:35 PM
The car in questionn is an 02' C5. I have heard a few instances where the pin that holds the roller wheel on has broken or fallen out.
Old Oct 4, 2003 | 06:55 PM
CHRISPY's Avatar
I lost a couple of lifters. 50K miles on the stockers. I was running a 230/230 112LSA XE-R cam with them but threw in Comp R lifters afterwards.
If you have the heads off swap out the stockers IMO. Especially with any sort of double spring and aggressive lobe.
Old Oct 4, 2003 | 06:58 PM
jrp's Avatar
jrp
SN95 Director
whats a lifter problem sound like, what are the symptoms?
Old Oct 4, 2003 | 06:59 PM
Colonel's Avatar
With the older lifters (pre-'01) the support around the roller goes all the way around rather than having gaps. This is a beefier design in this regard. The later model lifters sometimes (but rarely) are prone to cracking in this area. I assume they may have changed this to reduce the valvetrain weight a bit.
Old Oct 5, 2003 | 02:41 AM
Gold Phoenix's Avatar
I changed mine due to a mechanical over-rev because valves, pushrods, and lifter were damaged. I raced with this damage and picked up 2mph in the quarter-mile after the repair. If I did a cam change, I wouldn't use the stock lifters.
Old Oct 5, 2003 | 11:47 AM
Cal's Avatar
Cal
Are Comp-R lifters lighter than stock (2001)?
Old Oct 5, 2003 | 12:04 PM
SmaknaSS's Avatar
I would like to know this too.
