guy running 58cc come in!!
Old Jan 16, 2009 | 02:33 PM
johnster's Avatar
Default guy running 58cc come in!!
what pushrods r you guys running with a .040 gasket and stock rockers? 7.4 or little shoter like 7.350 thanks
Old Jan 16, 2009 | 05:58 PM
bww3588's Avatar
that depends on your cam if it has a smaller base circle, and what lifters your running.
i had an MS4 cam with LS7 lifters, .040 gasket and 58cc chambers on 5.3 heads, and i ran the .350's, but i want to say that was wrong because the engine never made the power it should have, and everything else in that motor was dead nuts on. instead of correcting it, i decided to build a 408.
Old Jan 16, 2009 | 05:59 PM
01FbTaWs6's Avatar
im running 7.400
Old Jan 16, 2009 | 11:37 PM
johnster's Avatar
i am going to run the vindicator cam 240/244 608/598 on 112 its a comp cam i have as 5.3 heads 2.02/1.6 valves mill to 58cc ls7 lifters
give me some more in fo
Old Jan 17, 2009 | 12:08 AM
5.3LJimmy's Avatar
I measured mine and the 7.350 was the closest match. I would think your setup would require the same, but it's always best to measure.
Old Jan 17, 2009 | 11:43 AM
studderin's Avatar
I ran 7.350 with a streetsweeper cam. 58-59cc 241 heads
Old Jan 17, 2009 | 06:03 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
You should always measure. A pushrod length checker is cheap.
Old Jan 17, 2009 | 09:56 PM
johnster's Avatar
ya ur rite i going to buy one thanks guys
