oil pan clearance/ windage tray
Just wondering how much clearance you need between the pan and tray for a wet sump, have a k-fame in the way. I have no more than 1.800' or 45mm from block to outside bottom of pan. I were going to use a dry sump but it's going to cost a heap while the AUS dollar worth half to the US dollar.
So as long as the windage tray don't touch the oil pan, i have enough clearance?
I'm trying to keep engine low as possible in the engine bay to help the bellhousing and box to fit. I can rise the engine height a little but it causes more problems
I,m putting a ls1/5spd tremec in a LC Torana, which is a 1000kg factory 6cyl car. If i raise the engine it will hit the bonnet, and if i lower it everything gets easier.
This is my problem.
the red line is where it needs cutting. Which will leave 1.800' from block .
http://s4.photobucket.com/albums/y14...t=lcls1pan.jpg
This shows the ls1 sitting in the engine bay
http://s4.photobucket.com/albums/y14...reen/lc%20ls1/
This is my problem.
LS1Tech Premium Sponsor
Make sure to give it a little more clearance than you think it needs...many people don't take into account expansion of metals, deflection, etc when they're shimming the windage tray and it hits when they actually run the engine (it didn't hit on the stand when rolled over).
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
