Tsp .220/.220
Old Jan 18, 2009 | 11:04 AM
Scarface20_03's Avatar
Question Tsp .220/.220
I just recently had to change up cams for my build. I have a stock bottom end LS1 and decided to go with a 317 casting head with Livernois .690 dual springs and 2.05 intake valves. My originial cam was a custom grind .236/.242 .597/.6?? on a 112 lsa. Due to PTVC I've decided to use a TSP .220/.220 .581/.581 lift on a 113 lsa. I was wondering what RPM this cam's power might come in.
Old Jan 18, 2009 | 11:31 AM
LS1-450's Avatar
Should be better low end torque & will continue make good HP through 6300 RPM.
Old Jan 18, 2009 | 07:17 PM
Does anyone know what kind of numbers it might make on the dyno with a set of 317's milled with 2.05 intake valves? Compression should be close to 11.0:1.
