witch gasket on lq9 heads ?
Old Jan 18, 2009 | 09:23 PM
elias_799's Avatar
Default witch gasket on lq9 heads ?
i am going to install lq9 heads on a ls1 block and i have 2 mls head gaskets part #12589226 . i have placed them over the combustion chamber on the lq9 heads and they seem fine. but i just wanted to make sure. any help would be appreciated.
Old Jan 18, 2009 | 10:58 PM
GMCtrk's Avatar
The ones I have are part # 12589227. I'm not sure what the difference is. What I have is the 4.020 MLS gasket
Old Jan 18, 2009 | 11:12 PM
elias_799's Avatar
i think you have the gaskets for an lq9 motor, i have gaskets for an ls1 motor.
Old Jan 19, 2009 | 12:45 AM
1FastBrick's Avatar
#12589226 -LS1 5.3L HO/5.7L GM MLS Head gasket LS1 02-04/ 05-07 5.3L HO
#12589227 -6.0L GM MLS Head Gasket SAME for LQ4, LQ9, LS2
here you go...
http://www.performancetrucks.net/for...d.php?t=428941
Old Jan 19, 2009 | 07:45 AM
elias_799's Avatar
here you go...
yea i knew that. i was asking if the ls1 mls gasket will work with the lq9 heads that i am installing on my ls1. thanks
Old Jan 19, 2009 | 08:37 PM
elias_799's Avatar
bump for more answers
Old Jan 19, 2009 | 08:42 PM
1FastBrick's Avatar
You should use the 6.0 Gasket since it will better match the combustion chamber on the head. I believe the 5.7 would over hang the chamber on the head and May not seal properly... I know it was explained on here before by Richard from WCCH...
Old Jan 19, 2009 | 09:38 PM
elias_799's Avatar
Thumbs up
thanks, that is exactly what i was looking for. if you have a link to where it was explained i would really appreciate it. thanks again
Old Jan 19, 2009 | 09:40 PM
1FastBrick's Avatar
Sorry,I have been searching but I can't seem to find it... Maybe you could shoot him a PM and He could Explain it real Quick for you...
Good luck!!! If I do find it I will post back
Old Jan 19, 2009 | 09:58 PM
GMCtrk's Avatar
You need to use whatever head gasket GM used on the LS6
Old Jan 19, 2009 | 10:14 PM
elias_799's Avatar
aren't the ls6 gaskets exactly the same as the ls1 gaskets ? it is basically the same block.
Old Jan 20, 2009 | 12:31 AM
405HP_Z06's Avatar
Measure the width of the combustion chamber and cylinder bore diameter. Use a head gasket with a bore diameter larger than both measurements and in the thickness you prefer.
Old Jan 20, 2009 | 06:24 PM
elias_799's Avatar
thanks, i made up my mind and i will go with the 6litre gaskets, that should solve everything.
