Torquer v2 or v3
Old Jan 19, 2009 | 11:22 AM
mook99ta's Avatar
Default Torquer v2 or v3
How would this cam work with the stock stall? I had a stall in my old TA and couldn't stand driving it on the street. Just wondering if I would have any issues with this cam and stock stall
Old Jan 19, 2009 | 11:26 AM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
The biggest cam I would recommend running on a stock converter is a 228R on a 114 LSA, and even that is pushing it. You would probably have problems with the car wanting to push through the brakes due to the lack of vacuum and the stock converter being too tight for cams that size.
Old Jan 19, 2009 | 01:22 PM
mook99ta's Avatar
Is there anything besides a converter that would solve that brake issue ie a vacuum booster or anything
Old Jan 19, 2009 | 02:24 PM
No that is the only streetable way to solve that issue in an automatic car.
Old Jan 21, 2009 | 01:32 AM
BriancWS6's Avatar
I've personally ridden in a stock stalled 224/224 112 cammed car. The thing was a TURD in the low-mid range due to the tight verter. Anything of ANY size at all, will need a higher stalled converter. You will see a larger gain in performace doing a stall alone vs trying to stuff one of those cams in there with the stock torque converter.
Old Jan 21, 2009 | 03:42 AM
thunderstruck507's Avatar
I have a comp 230/224 111+3 similar to a tr230 but less aggressive lobes and a stock stall
I hate it. When put into gear it idles up to 1000rpm and it takes a LOT of pressure to hold the brakes on. Pretty much safer to shove it into neutral every time I'm about to stop.
Feels like crap at heavy but not wide open throttle until the rpms hit 3000, then all of a sudden its like an off/on switch and the car starts pulling like crazy
I can't wait to get a stall to make it less annoying to drive
Old Jan 21, 2009 | 07:31 AM
mook99ta's Avatar
So with the torquer 2 or 3 would 3000 be a good stall or would I need higher. Remember this is a street car that sees the track maybe once a year
Old Jan 21, 2009 | 10:31 AM
Jon@Texas-Speed's Avatar
I would go 3000-3200 stall speed. Either one will work great with those cams and still drive good on the street.
Jon
Old Jan 21, 2009 | 10:45 AM
J&J Motorsports FL's Avatar
What year was your old TA Mook99?
Old Jan 21, 2009 | 11:45 AM
BriancWS6's Avatar
I had a 3500 stall in my previous 225/225 cammed car. If I ever do another auto, I'll go bigger on the stall.
Old Jan 21, 2009 | 02:46 PM
03_SS_22's Avatar
stock stall the most i would go is 224 cams
but the tv3 on a high stall would be awesome!
Old Jan 21, 2009 | 04:21 PM
mook99ta's Avatar
was a 98
