MS3 in an Auto?
Old Jan 19, 2009 | 09:39 PM
maskedman58's Avatar
Default MS3 in an Auto?
Im considering putting a MS3 cam in my Z28. its an Auto with the stock stall and stock rear end. I dont have headers on it now but will when I put the cam in. would it work ok considering the stock aspect of the car?
Old Jan 19, 2009 | 09:44 PM
BadBandit69's Avatar
no that cam will not work with the stock converter. when you get a cam tuned they raise the idle and it will be very difficult to hold the car stopped at a light. plus if you do manage to get it to stop pulling forward the engine will usually die. the largest cam that is considered ok for a stock converter is a 224/224.
Old Jan 19, 2009 | 10:22 PM
so would a 3500 be good or should I go 4000?
Old Jan 19, 2009 | 10:24 PM
SOMbitch's Avatar
a3600-4000 stall is perfect for that cam N/A in a 3.23/3.73 gear.
Old Jan 20, 2009 | 04:32 PM
BJSS25's Avatar
I have the MS3 in my auto, I have a custom built TCI 4400 stall built for spray. I would go with at least a 3800 stall and 3:73's. If not it will be a dog down low in the rpm range.
