454 lsx with afr 205's?????
The heads would work better than you think out of the box, and work even better if I ported them spending the majority of the focus unshrouding the chambers to compliment the larger bore. Its probably worth 20 additional HP on that engine.
With the ported head, the right cam, and a properly ported FAST I bet the engine would make 530-540 RWHP and close to or greater than 550 RWTQ.
The engine would have absurd part throttle response and "tip in power" at practically any RPM. It would make for a REALLY fun street car that could fry the tires at will in any of the lower two gears.
With the right tire whoever on a raceprepped track I bet the car would also be capable of some serious quarter mile ET and trap speeds as well....
Contact me if you would like more info or help with the combo....I would love to be involved in as unique a project as this.
Cheers,
Tony
PS....The best thing about this engine would be how early and "accessible" the big numbers would be. Im guessing its making over 500 RWHP by 5000 RPM's....hell....maybe sooner. Probably over 450 RWTQ by 3000!!
Cheers,
Tony
1 Post
Cheers,
Tony
Cheers,
Tony
Cheers,
Tony
Cheers,
Tony
1 Post
I kept my heads to help control cost as well. Afr 205s are a very good head, and work well on a 402. Just not going to make the same PEAK numbers that a bigger set of heads will make, but TORQUE will be abundant everywhere.
