Collapsed lifter - dirt in it?
Old Jan 23, 2009 | 04:03 PM
01Z28Camaro's Avatar
Originally Posted by FlashLCD33
What do you guys think..
Should I -
A - order an o-ring and replace just that, to see if the tick is related to it.
B - order lifters and o-ring, and just do it all at once
You know the answer
You should do B
Old Jan 23, 2009 | 04:20 PM
aNuBiS's Avatar
Should I -
Well, what kind of mileage do you have on the motor right now, that may help influence.
Old Jan 23, 2009 | 04:37 PM
FlashLCD33's Avatar
Old Jan 23, 2009 | 04:40 PM
aNuBiS's Avatar
Tough call. But its enough to warrant a complete lifter change 'just cause'
Worse case, you got all new lifters. Plus, you'll get a chance to have a look at everything else inside while youre at it.
Old Jan 23, 2009 | 04:49 PM
FlashLCD33's Avatar
Ya, I have a shop to do it in and plenty of tools. Might as well.
Old Jan 23, 2009 | 05:09 PM
jarednut4ever's Avatar
It's just wierd to me how it was fine before the cam and when you restarted it after the cam it ticked. It sounds like a oil pressure thing to me. I know lifters can collapse but that is wierd how it was right after the cam install. Oil pressure is a funny thing it might just be the way the oiling system is that #7 is last in line and it is bleeding off. If it was me I would change the oring and see what happens.
Old Jan 23, 2009 | 05:12 PM
FlashLCD33's Avatar
That's exactly the thing. The only other thing I can think of is since they're stiffer springs maybe they're putting more stress on the lifter cup, and maybe it's just worn out.
Old Jan 23, 2009 | 05:17 PM
does the lifter still have spring to it. All your lifters after the car is off for a while should move a little
Old Jan 23, 2009 | 05:21 PM
I think you should just sell me your cam lol
Old Jan 23, 2009 | 05:23 PM
FlashLCD33's Avatar
Lifter has a little spring to it. I can pull the valve cover in like 2 min, all of the others are still pumped up and the #7I has no resistance.
Old Jan 23, 2009 | 05:30 PM
Ya like I said The others will be pretty damn tight they might move a little but shouldn't move easy by any means. If it moves that easy it is probably bad. But i would still try the Oring first cause it might just be that simple. As a mechanic that is what I would try here at work.
Old Jan 23, 2009 | 05:33 PM
  #32
FlashLCD33's Avatar
I'll probably order all of it, if the o-ring works then I'll keep the lifters, gaskets, and bolts for when I do a set of ported heads.
Old Jan 23, 2009 | 05:37 PM
  #33
Heads too, Damn money bags lol. Thats sounds like a good plan. I hope you get it figured out by first t&t other wise you forfit to me. Good luck man. Keep us posted
Old Jan 23, 2009 | 06:00 PM
  #34
FlashLCD33's Avatar
Lol the heads won't be for a while. Maybe a graduation present for myself in May?
Old Jan 23, 2009 | 06:04 PM
  #35
mvvette97's Avatar
The reason used lifter seem to fail after a cam change is because on every cam swap stiffer valve springs are used and the lobes of the new cam also puts more of as beating on the lifters. The stock cam has really mild lobes and the stock springs are pretty soft also. So a worn lifer will work ok with the mild parts. Start getting aggressive lobes and stiff springs then the old lifters to to crap out.
Old Jan 24, 2009 | 04:06 AM
  #36
slowassta's Avatar
not to scare you but i think this was the cause of my LS7 lifter failure only after 5k miles or so
https://ls1tech.com/forums/generatio...pper-pics.html
Old Jan 24, 2009 | 08:04 AM
  #37
vettenuts's Avatar
Just a by the way on this as I don't know if dirt is the problem. I have had my heads off twice now. I have been very careful with regards to getting dirt down into the oil gallery where the lifters are when the lifters were not in the motor. Both times, as a final check before installing the lifters, I was fortunate enough to borrow a laser powered articulating boroscope from work. Both times I found dirt in the oil gallery and then cleaned it out. You would never see it without the boroscope. Guess what I am trying to say in a round about way is that it would be very easy to get a piece of dirt in there no matter how careful you are when you work.
Old Jan 24, 2009 | 11:38 AM
  #38
88blackgt's Avatar
replacing lifters is much better than wiping a lobe, especially going from stock lifters anyway
Old Jan 24, 2009 | 04:24 PM
  #39
TopFlite's Avatar
Well put. The original and unchanged LS1 lifters are meant for use with the stock cam.
Old Jan 24, 2009 | 04:36 PM
  #40
98Camarod's Avatar
You might want to plan on a tad over 300, gaskets, head bolts, lifters, and coolant.
