patriot valve seal help
i was wondering if you guy can help me find some good valve seals that fit the patriot dual valve spring. mine are currently burning oil and its killing like 1-2 quarts every 1000 miles or so.
Patriot sells the seals as well. Here's a link. https://www.patriot-performance.com/...&cat=51&page=1
I reread your post. That seems like alot of oil to burn to be seals. Were the rocker bolts sealed? They open into the intake ports, when ported. You should maybe have a leakdown/compression test as well.
Also, the Patriot seals are pretty top notch. Unless you have tons of miles, or ran the motor hot. They seem unlikely for that much oil useage
You really should NOT be having that issue with the Patriot seals. They are identical to the seals GM uses on the exhaust side. Are you sure they were fully seated before you installed the springs? As asked above did you put sealant on the intake rocker bolts? I hate to ask these types of questions, but that kind of oil consuption on an otherwise stock motor makes me wonder.
Thanks,
Shane
Thanks,
Shane
well actually i am running an ms4. all i remember is that the valve seals were seated and they were brown in color. i was told that those werent good to order some viton seals.
Those seals are one of the best, So I wouldn't listen to who is telling you otherwise.
The few things already mentioned in this thread need to be checked. Even if it was a couple bad seals, you wouldn't use that much oil.
Here's some maybe's;
valve guides
rings
pcv set up
How many miles are on the car? Does it smoke on start up, accel, or decel? What weight oil do you use? Have you been running the car harder since the cam?
It honestly doesn't sound like valve seals at all. Unless they weren't seated all the way. Were they already installed? If so, that to me, would rule them out even more.
I'd get a leak down/compression test done with that much oil usage.
valve guides
rings
pcv set up
As stated above, those are high heat seals and are some of the best you can use. If the seals were installed properly and you have no seal to retainer clearance issues, then your problem lies elsewhere.
Shane
thanks guys i'll pull apart the covers and check it out. i did replace them with the cam install. the car does smoke on start up and on acceleration and the smoke is white in color, i dont really run the car hard, also car has 74000 miles. i use mobile 10 40w. the funny thing is that my car does not run hott and oil pressure is always high.
Last edited by formula402; 01-27-2009 at 06:03 PM. Reason: added more to my original post
