5.3 head and cam combo
Old Jan 24, 2009 | 03:07 PM
TDPB2008's Avatar
Default 5.3 head and cam combo
i have a 98 transam ls1 with a a4 iwant to go with a head and cam swap im lookin at texas speed 5.3 2.5 heads with eather the 233/239 cam or a more agressive ms3 cam, also i need a stall also so im thinking tci 3500 lockup and 3.73 gears? am i heading in the right direction? do i need to know about anything else like piston clearance with those heads? any info is a big help thanks-matt
Old Jan 24, 2009 | 06:06 PM
conan's Avatar
What other mods do you have? If you have the supporting mods (exhaust,intake) You'll see some nice gains from the tsp H/C set. Give them a call monday and they'll tell you if you'll have any PTV problems and a good stall to match their setup.
Old Jan 24, 2009 | 06:10 PM
TDPB2008's Avatar
just a slp loudmouth and a powerprogrammer no internal engine mods
Old Jan 24, 2009 | 06:13 PM
conan's Avatar
I would look in to a ls6 intake, headers, and a y pipe. To get the most of H/C combo.
Old Jan 24, 2009 | 06:23 PM
TDPB2008's Avatar
but what do you think of that set up and what cam would you go with with that stall and stuff?
Old Jan 24, 2009 | 06:32 PM
Kingc8r's Avatar
Add an electric cutout, I wouldn't go with a stall that is under 3600. Personally I would go with a 4000-4400 stall.
I would only use three converter companies. I would go with Yank, Circle-D or Vigilante. Not in that order specifically.....
LS6 didn't show me any great gains, I'd look into a FAST 90/90 or 92/92 since you are doing H/C
Old Jan 24, 2009 | 06:39 PM
TDPB2008's Avatar
ok thanks any info will greatly help
Old Jan 24, 2009 | 09:31 PM
bigftruck's Avatar
i just finished a ms3 stage 2.5 5.3 combo and love it. im an m6 but with the ms3 and an auto i would prob go with at least a 3800-4000 stall. If you buy them as a combo from tsp they will sink the valves a little to run the ms3. with the other cam they wouldnt have to i dont believe. call tsp up though they are very knowledgeable and very friendly and helpfull.
Old Jan 25, 2009 | 11:32 AM
SOMbitch's Avatar
Tci=crap
Old Jan 26, 2009 | 11:04 PM
TDPB2008's Avatar
what do you guys think of 233/239 cam with stock heads and 3500 stall and 3.73 gears is this a good setup
Old Jan 26, 2009 | 11:42 PM
TDPB2008's Avatar
anything
Old Jan 27, 2009 | 12:15 AM
Blu99T/A's Avatar
I have seen alot of good numbers and performers from the Speed Inc S15 cam. It is the 231/237 cam.
Old Jan 27, 2009 | 09:00 AM
TDPB2008's Avatar
is that on stock heads you saw good numbers??
Old Jan 27, 2009 | 09:04 AM
conan's Avatar
I think you would see some nice gains from that. Get some opinions about the stall, I'm a M6 guy so I dont talk stalls. But the cam and the gears will wake it up for sure.
Old Jan 27, 2009 | 09:11 AM
Blu99T/A's Avatar
The guy I got my TSP 5.3 heads from put down right at 450rwhp with the S15 cam, 90/90, TSP 5.3 heads, through a 9in rear.
Another guy I know personally puts down right at 400wrhp with a cam only 231/237 with stock 853 heads, LS6 intake, LT's.
Old Jan 27, 2009 | 09:49 AM
CodeRed2000SS's Avatar
yea but are they 6 speeds? if they are they will naturally produce more hp. honestly the tci is not a good converter for the ls cars. i have seen problems with them not locking out. but go with whatever your budget looks like. i run a yank and have installed vigilante and they both are awesome converters. i wouldnt get over a 3600 though. a 4000 is too much stall for what you have at the moment. i run a yank 3600 in my car and it works perfect.
Old Jan 27, 2009 | 11:03 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
We've done tons of the PRC Stage 2.5 5.3l heads & cam combos. I recently finished a Tsunami & PRC Stage 2.5 5.3l heads car that made right around 450rwhp!
http://www.texas-speed.com/shop/item...id=84&catid=20
http://www.texas-speed.com/shop/item...d=203&catid=47
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Apr 14, 2009 | 04:44 PM
99Ls1fever's Avatar
Do you have a dyno chart to throw up on this topic with the tsunami cam and 5.3 heads?
