Trick flow or patriot heads
Is there a reason other than $$$
BUT,.... you get what you pay for.
I currently have a set of the AFR 225's on my SS with a 2.05/1.57 Valve setup and Stock Rockers.
They are an Excellent head BUT they seem to be dying out around 6800-6850 RPM when I'm crossing the Big end at 7500 RPM.
So, I'm bumping up to a larger Head...
The All Pro LS-2's with a 244 Intake runner and a 2.08/1.60 Valve setup (Coated-Titanium Intake valves and a set of T&D 1.8 Adj. Shaftmount Rockers).
Had them flowed at All Pro with the new valves. Looks to be at .650=340.8
Looks to be a Helluva Performance Gain
We also can set you up on the PRC line-up if you're looking at more of a budget cylinder head
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
N/A @ 3650 lbs Race Weight. The SS has been a best of 10.42 @ 124mph w/ 1.42-60'
Did I mention that it's still a 347ci. with All Forged Internals and built by FMS, has a FLT 4L65E Level 5 Tranny w/ a YANK 4k Stall
and a Moser 9" w/ 4.71 gears and a Detroit Locker.
I'm debating about replacing the FAST 90 with either a Super Victor Jr. or another one I've seen on Tech.... I just can't find the post.
Yes, I know..... a bit much for the lil ole 347ci.
BUT... I'll be building an LSX 440 Bottom end here real soon. This time I think I'll go Solid Lift
i had a set of ls6 castings with stock valves from patriot flow 299.9 at .650
i think the exhaust was 228.x
they are worth every penny for the price, but in no comparison to the TFS head.
search the dyno section, even moreso on 400+ inches.
average patriot does 480-490 ish, while a tfs will put out 520-530
