Cometic Head Gaskets
Old Jan 25, 2009 | 07:12 PM
luckyhenriksen's Avatar
Default Cometic Head Gaskets
Can I use the thinnest head gaskets they make (.040) to raise my compression a little? On my carb'd LQ4 with L92 heads.
And can I use regular head bolts with my L92 heads or do I need special ones?
Thanks, Steven
Old Jan 25, 2009 | 07:28 PM
405HP_Z06's Avatar
Yes you can. Here is what I calculate your compression to be now and after using a .040, 4.039" bore gasket.
Compression now using a GM MLS 6.0L head gasket:
Compression with a .040, 4.039" bore head gasket:
Old Jan 25, 2009 | 10:12 PM
Sweet thanks man
Old Jan 25, 2009 | 10:59 PM
slowandrichws6's Avatar
yes you can as stated above, just thought i would say it too lol
