Oil pan install / o ring question
Old Jan 26, 2009 | 01:33 PM
sman's Avatar
Default Oil pan install / o ring question
For my swap Im using a iron 5.3 with an fbody pan. Not done much work on ls series before, but I keep seeing threads on people with oil pressure problems and it keeps mentioning this "o ring". Is that the o ring on the pickup tube?
My new one is blue, I thought I remember reading about different colors, is one newer than the others?
To my knowledge people pinch this o ring, how? Just over tightening? What would that have anything to do with it? How can I avoid screwing this up?
Old Jan 26, 2009 | 01:48 PM
1.8t's Avatar
What they do is they leave that O-ring inside the oil pump and when fitting the pickup tube back onto the oil pump, they cut it with the pick up tube. You want to put that O-ring on the pickup tube first and then seat the pick-up tube back into the oil pump.
Old Jan 26, 2009 | 02:02 PM
sman's Avatar
Ahh, ok. Do you happen to know the torque spec on the pickup tube or just good n tight?
Old Jan 26, 2009 | 02:03 PM
XtraCajunSS's Avatar
The blue one should be the factory GM o-ring for a non-truck pickup tube which is what you are using. As stated above, install the o-ring on the tube first, lightly oil it then insert into the pump body.
Shane
Old Jan 26, 2009 | 05:20 PM
TheLS1Kid's Avatar
The correct torque specification for the pickup to oil pump is 106 in-lb.
That is INCH POUNDS.
It comes out to about 9 ft-lbs. if you don't have an inch pounds torque wrench.
Old Jan 26, 2009 | 08:02 PM
S10xGN's Avatar
Shane
Hey Shane, are us peeps with truck pan/pickups supposed to use a different O-ring? The one I put in my setup is the blue one, but I think there's an orange one laying around somewhere....
Russ
Old Jan 26, 2009 | 09:25 PM
Yes Russ, the truck o-ring is usually thicker... you should compare it to the one you took out.
Shane
