LS1 to LSX do I need conversion parts?
Old Jan 26, 2009 | 08:07 PM
The Fugitive's Avatar
Default LS1 to LSX do I need conversion parts?
Okay so I am thinking of doing the opposite of everyone and get a LSX block and not a LS7 don't really care about weight just reliability and security if something goes wrong. But I was wondering do I need a conversion kit like all the other blocks (LS2/3/7) or am i just fine with getting the block and doing an install?
Old Jan 27, 2009 | 02:17 PM
deadmanTA's Avatar
PM or call TSP they would be able to tell you.
Old Jan 27, 2009 | 02:19 PM
HUNTER02SS's Avatar
You will need a LS2 front cover and timing chain and LS2 valley cover. The block should come with the cam retainer,lifter holders.
Old Jan 27, 2009 | 02:22 PM
2000Hawk's Avatar
I emailed LME and they quoted me an LSX, and included in the quote was an LSX Block conversion kit. Which comes with double roller timing set w/ torington bearing and nitrided gears, timing cover w/ cam sensor, valley cover, and cam/knock sensor extension harness. So if anything give them a call or email them, im sure they can point you in the right direction.
-Joel
Old Jan 27, 2009 | 11:54 PM
thanks for the help I thought it would be able to go directly into a LS1 no problem. I guess I should rethink my options cause I thought it would be less trouble than the others.
Old Jan 28, 2009 | 09:16 AM
Jon@Texas-Speed's Avatar
You will need to conversion kit for any LS2/3/7/9 and LSX block in an LS1 car. I would also recommend using a lifter with a tie-bar rather than using the supplied LSX lifter trays. We have seen issues where the lifters are not held square in the lifter bores. Let me know if you have any other questions and we can get them answered for you!
Jon
