help!!! cam and head milling help!!!
Old Jan 28, 2009 | 08:45 PM
THENASCAR's Avatar
Default help!!! cam and head milling help!!!
ok heres the story. i have 241 heads. getting fully ported keeping the stock valve sizes.by a friend(graduate of SAM school) and i have a thunder racing TRAK cam
EXACT SPECS:
duration @ .050
intake 233 exhaust 236
valve lift with 1.7 rockers intake .644 exhaust .597
LSA 111.5
is there some sort of formula i can use to figure out how much i can safely mill the heads. i was hoping for .030 on these heads??? so i need help!!!
Old Jan 28, 2009 | 10:29 PM
JPH's Avatar
JPH
EXACT SPECS:
duration @ .050
LSA 111.5
Not really. To many variables. Valve job will help you. If you don't mill them, you should be OK. But if you do, the intake valve will need to be verfied. It would be close.
Old Jan 29, 2009 | 06:27 PM
NINE8TA's Avatar
BUMP we need more info
Old Jan 29, 2009 | 07:41 PM
elias_799's Avatar
why do you wanna mill the heads ? to raise the CR or just to make sure they are nice and flat ?
Old Jan 29, 2009 | 09:09 PM
THENASCAR's Avatar
compression gain. if i wanted to get it flat i would just go .005 or .010
Old Feb 3, 2009 | 07:41 PM
THENASCAR's Avatar
Bump!!!!
