cheap lq4 build ??'s
Old Feb 10, 2009 | 05:53 PM
cabech984's Avatar
My "budget" LQ4 build consists of the following, so far;
67K mile 02 LQ4
PRC Stg 2.5 5.3L Heads(59cc Chambers)
Custom Grind 23x/24x .6xx/.6xx 113LSA
FAST 92/92
Ported oil pump
Katech Rod Bolts
LS2 Timing Chain
CTS-VR Lifters
Got alot more to buy and alot more money to save but should run real nice in front of my TH400 in a 1990 Firebird
Old Feb 22, 2009 | 01:21 AM
billyflantos's Avatar
it's up and running,that msd 6010 box is the easiest box i ever hooked up fired right up no problems.sounds healthy should have track times next week end......
Old Feb 22, 2009 | 06:53 PM
took it down the road for a test drive today got some heat in the motor layed into it in first started spinning 26 10 slicks cracked the gas pushed it up into second to catch traction went back into the throttle glanced down at the gauges for some stupid reason and when i looked up i was half way in my neighbors ditch cleaning it out for him smiling the whole time.......
Old Mar 4, 2009 | 11:50 PM
looks like this week end i'll get some times on it...
Old Mar 7, 2009 | 07:04 PM
went to mooresville dragway today got to make three pass's first pass 7.13 shifting at 6000 grand second pass up'd the shift point 6300 went a 7.07 third pass shifted at 6500 went in the 6.90's and spun a little bit.
Old Mar 7, 2009 | 10:00 PM
ksk1980's Avatar
^^^not bad at all
