317 heads on n/a ls1?
so I called up my machine shop to ask about getting some valve/porting done to either my heads or some 243's while they were off. turns out he has a set of very clean low mileage 317 truck heads at his shop that he can port and mill for me
he was figuring he would mill them about .020-.030 to get to stock CR and clean up the ports a bit and do a valve job on them
I know people use these heads for FI since they lower CR with the larger chamber, would this work well on n/a with the gt2-3 cam if he mills them down? anything special port / polish wise i should ask for
anything I will need to do special for this set up, would i need diff length pushrods, and what head gasket do i need? will ls2 gasket work since they are both 6.0? would a thinner gasket help also .045 or .050 possibly
I realize 243 heads may be better than these heads for an n/a application but will this work since they are available and inexpessive.
