No it is not nessacarily Trash. The only way to weld it up would be to bore the 2 liners out, weld it up, install new liners and then deck it... There is a reason it cracked there (probally from overheating) an untill the liners are out you probally won't know... This has been done before on LS block. and I am sure if you talk to someone with a lot of experince with the LS1,LS2,LS7 blocks you will find they have had to repair at least a few of the here and there and that is most likely the same process they used.
