Timing Question
Old Feb 3, 2009 | 11:27 AM
H8TO WRK's Avatar
Default Timing Question
I am getting ready to put my LS6 together for my jeep Wrangler and I think I have everything all figured out however setting the timing has me a little concerned. Can you try to answer a few questions for me?
Can I just use a base timing setting? Or because I have a cam in it do I need to make adjustments?
Point me in the right direction if you can. I bought a book that goes through a lengthy procedure for checking and setting timing after a complete rebuild however I am not doing a complete reuild.
I bought the motor complete but the original owner had some parts removed that he used for another he build.
Old Feb 3, 2009 | 06:19 PM
Chris10an's Avatar
is it a EFI setup or a carburator engine?
Old Feb 3, 2009 | 06:50 PM
blk00ss's Avatar
All you have to do is line the timing marks up. If you are using a stock timing set, there will be a dot on each timing gear. You will want to get those lined up perfectly. And I believe most aftermarket sets use numbers. So "0" would be like the "dots" on a stock set.
