Do Head bolt threads get lubed before installing?
Installing Head bolts do the threads get lubed or a light application of engine oil?
I'd take one of your old head bolts and grind some notches in to the threads (like a tap) and run it in/out of each head bolt hole to clean them out. The notches will help clean gunk out.
x2.0 the part number is 912-0011 if any one is interested.
Also the book calls for a torque of 15ftlbs + 90 degrees after the torque on the M11 bolts, is that right sound a bit much too me. My engine is an "03" Gen III
I usually recommend my customers at least get the ARP bolts. Stronger than stock, don't require any angle TQ'ing BS, and a little 30wt oil on them and their good to go.
To answer your question, install new GM bolts as-is, no lube or additional threadlocker needed, using the (corrected) specs quoted in my book. ARP or otherwise, follow their instructions for both lubrication and tightening.
This is the correct method. No lubricant with stock head bolts is needed or recommended. Torque angle does not require lubricant as the thread pitch determines bolt stretch.
Shane
Thanks
Best of luck on the build!
i use the sharpie method to mark my bolts and all is well.
i have head studs on my new build, only becuase they came with my block.
its all dependant on the power level as well.
i wouldnt use a stock bolt on a 900hp boosted setup, but for the average head and cam guy, that 300 bucks in studs is better spent elsewhere.
