Solid Roller Cam 408ci lsx
Old Feb 4, 2009 | 10:04 PM
boydcoz71's Avatar
Default Solid Roller Cam 408ci lsx
I was thinking about changing my Head's Cam and Intake set up here is a list of my current set up
Iron 408ci
Stock L92's W L76 Car Intake NW 90mm TB
248/258 .647/.647 113+3
Comp 921 springs
I was thinking about getting a set of AFR225 heads and a carb intake and a solid roller cam shaft do you think that would be a good move etc ?
what set up would you go with ? heads ? cam ? springs? intake? also thinking about going carb set up
Old Feb 4, 2009 | 11:19 PM
KCFormula's Avatar
Send your heads out to a good porter for a "big cube" port job and then have a cam matched from Futral or another major solid roller user.
I don't think you need to get different heads. Just maximize what you got and you will be fine. I run ported 243 castings on my 421.
Old Feb 4, 2009 | 11:57 PM
boydcoz71's Avatar
what kind of valvtrain do i need to buy ? and should i get a single plane intake ?
