advise on Titanium valves
Old Feb 7, 2009 | 12:41 AM
70camaro's Avatar
Default advise on Titanium valves
I just picked up a set of stock size Del West titanium valves and I'm not sure what I would need to do to my LS6 heads to run them. Will the stock valve seats work? Do the titanium valves need special spring pressures or could I run my Patriot dual springs without any problems. I am also going to run the Patriot cam 225/229, 580/590 if that makes any difference. Thanks for any advise anyone might be able to give.
Old Feb 7, 2009 | 07:59 AM
87silverbullet's Avatar
I think you have to change the seats out to a different kind of metal but I can't remember what. I was also told by my engine builder that they don't last long.
Old Feb 7, 2009 | 08:44 AM
Gregory's Avatar
Contact TEA. Total Engine Airflow is a sponsor on this site.
Old Feb 7, 2009 | 10:29 AM
Grimes's Avatar
Pretty sure you need special valve guides and seats.
Old Apr 19, 2009 | 05:02 AM
Hans Grüber's Avatar
Question
Does anyone know for sure?
Old Apr 19, 2009 | 07:16 AM
UGotBeaT's Avatar
you'll be fine running the seats in your heads with titanium valves. Make sure they both have the right seat angle on them..im assuming its 45 degree stuff. Double check installed heights with the new valves. Need to also recheck guide clearance and probably need to run at least a bronze liner or even a bronze guide.
Old Apr 19, 2009 | 09:22 PM
Whytail's Avatar
Old Apr 19, 2009 | 09:51 PM
S10xGN's Avatar
Aren't you supposed to run lash caps on TI valves?
Russ
Old Apr 19, 2009 | 09:58 PM
UGotBeaT's Avatar
If they dont have hardened tips on there you should..
Old Apr 20, 2009 | 05:43 PM
TJ's Avatar
TJ
these for the street?
id pass if its a daily driver.
with your car, there is lil power to be had, if any. that cam isnt agressive to need a superlight valvetrain.
Old Apr 20, 2009 | 05:57 PM
NastyC6's Avatar
need a hardened tip for sure,lash caps suck,i put 15k miles on mine,...there fine.u better let the shop set them up,.....dont matter how many miles u have on your heads. i run a 5 angle valve-job on mine,....
Old May 12, 2011 | 01:14 PM
fastsspr's Avatar
Russ
I don't know, what is a lash caps for TI valves? For what it have to be used?
Thanks
Victor
Old May 12, 2011 | 01:39 PM
KCS's Avatar
KCS
Moderator
Thanks
Victor
Titanium is relatively soft compared to steel, so you don't want a steel rocker rubbing on a titanium valve. You'll end up with a catastophic engine failure.
Usually, aftermarket titanium valves have a hardened tip above the keeper groove, but in the case of an LS7, a lash cap is used instead to provide a hardened surface for the rocker to make contact without damaging the valve.
