pushrod length question (yes, I did measure)
Changes over the winter break included having the heads ported and milled (0.012), as well as swapping out the original ls1-style lifters to the newest design ls7-style lifters.
All 8 cylinders (intake & exhaust) we're pretty close, so I added and averaged them all out to:
Intake: 7.356
Exh: 7.353
That is using a 0.075 pre-load.
They are close enouge I'll use the same length pushrod on all 16 valves. I really dont know what preload to use for the ls7-lifter.
Would it be better to go with a 7.350 or 7.375 length pushrod?
Intake: 7.356
Exh: 7.353
well, if 7.35x is with .075 already added, then stick with the 7.350's.
Going with the 7.375's would be almost .100 preload. Probably wouldn't hurt, but its a little on the high side, especially when your measurement is closer to 7.350 than 7.375
