Best heads for Torquer v.3
I will eventuall match it up with a Fast 90/90 but not just yet.
I want to build the car right and i have always heard of people mis-matching H/C combos with the cam being too big for the application or what not, and the car not performing right.
I have built my car too do the rear end and suspension, then tranny and clutch first, that-way the car will handle everything i throw at it.
I want something that will be in the range of 450 rwhp for a H/C combo, plus i will be spraying a 150 wet shot on it too.
The car is barely driven mostly a weekend type car and goes to the track 6-10 times a year.
So what are people opinions?
If you want to make it easier on yourself,Pat G can spec you a nice cam after you decide on what heads you want,A custom cam will probably perform better then any off the shelf grind,and a custom cam will also include the new lobe designs from comp,which are something to take advantage of.
get a custom cam or something proven like a TV3. if you go with the TV3 call up Texas speed and see what heads they reccommend- probably their 5.3's. I would try to get your compression around 11.3- 11.5. You will like the results.
I have a nice set up for me, makes great power down low- heads and compression, and works pretty dam well up top- cam. I mainly wanted a street car that can go to the track instead of making an all out track car.
I do really like the AFR heads but im trying to get a package for 2200$. LS6 AFR heads alone are starting around 2200$.
Keep in mind this will all be with a 150 wet shot too.
As far as the heads, since nitrous and compression are great together, id go with the 205's. the 225s are great, but i would probably say that you need a few more cubes to get the true benefit of those. so id get the 205's and mill them down a bit. that setup with spray, id be jealous
The PRC Stage 2.5 heads will work really well also, but the smaller chambers from the 215 heads really make great power across the board!!
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
