random cylinder missfire? WTF?
a4 or m6? mines is an a4 and when it does this the tranny shortshifts and won't downshift
Was it both of your front o2 sensors? and was the wire like burned up? how could you tell it needed to be replaced?
my car would miss and sputter until the engine was at operating temps.
change to a non projected or an autolite of the same heatrange.
when i switched to autolites, my problem dissapeared.
it might not be the plugs, but its the cheapest part, so look there 1st.
It shouldn't be a rear 02 sensor since they just check to see if the cats are working, and well you have no cats. Did you run 02 extenders when you installed the headers? The code will say something like B2-S1 or B1-S1 which means Bank2-Sensor1 or Bank1-Sensor1. Just remember:
Bank 1: Drivers side
Bank 2: Passenger side
Sensor 1 = Before the cat.
I replaced sensor 1 on bank 2 and had to unbolt my y-pipe, unbolt the cat from the manifold and drop it out. Let it cool down, spray it with penetrating oil and it should twist right off. Remember to hook the scanner back up after you install it and clear all codes. Did this a week ago and nothing has popped up since. Hope this helps? - Zack
