How do you install spirolocks?
taking them out is easier of course!
email at bnutter@wiseco.com tomorrow and I'll send you out a triple wound cs24 replacement. I'll send you some spares...cause you may mess up a couple more if it's your first time.
Basically you take the "end" of one and put the "fat" of your finger between it and the rest of the coils. Put this "end" into the groove with your right pointer finger and firmly hold it in there. Meanwhile (taking your left hand and a micro screwdriver), start to force the coil into the groove. it will walk if you don't start at 180 degrees from where the "end" goes into. ONCE you've established the 1st 1/2 coil in the groove, it's relatively easy to start pushing the rest of the coil down a little bit at a time counter clockwise until you have the entire thing seated. THEN give the whole thing a couple shoves a couple different ways to make sure it's really in there.
Don't fret much, the first time I did a set of 8 pistons...it took me 24 minutes...usually it takes 45 minutes for a first timer...even then you feel like replacing your first ones
Best regards, Brian Nutter-Wiseco
