1.9 rockers - stock modified
http://www.zzperformance.com/grand_p...=953&catid=104
"These started out as a stock rocker arms. The seats have been welded in and remachined at a new location to achieve a ratio of 1.9 (vs. the stock 1.7). "
i dont think YT offers this modification
5.3 cams have a valve lift of around .466/.457 on a 1.7 ratio rocker, which would be .523/.511 with a 1.9.
98-2000 f-bodys with the bigger cam which is .496/.496 lift on 1.7, which would be .557/.557 with a 1.9.
01-02 f bodys lift would be .524/.536
as for deflection on stock rockers i cannot speak on something i know nothing about maybe some one with more knowledge on this matter will chime in. as both test vehicles were 5.3's it is possiable a problem could arrise when you get into the higher lift of the early f-body cams with the high ratio of the rockers. if they could be used would be a sweet altertaniative to swapping to a z06 cam for those of us in FI applications.
"Bolts in exactly like stock. No modification needed for install. Direct bolt on affair. 1 Hour install time! A great simple alternative to installing a cam. No loss in fuel consumption and in some instances we have improved fuel economy."
I think the reason that they are so popular with the W bodies is the fact that they are really the only other alternative. They dont have huge amount of manuf jumping at the chance to make something new. Plus, after you have done all you can on the s/c side and gotten a cam, what else is there?
