AFR 225 Heads and Valve Springs question.
I need a new set of valve springs for my AFR 225's. I'd like something with about 160# on the seat and 400#+ at .600 lift.
The question is what is the largest diameter spring I can run with out cutting the heads? What inner diameter can I run?
I haven't pulled the springs off to see...
Ryan
Ryan
Why not just get the 8019's straight from AFR. They are drop in. I think they set up at 155# on the seat and should be over 400# open with your lift. Shims would raise the seat value if you need it. Contact Tony and confirm values but it would be a lot easier than machining the heads.
