head gasket question plz help
Old Feb 13, 2009 | 11:42 PM
showstoMpinSS's Avatar
Default head gasket question plz help
i know this might not work but will i need to replace the head gasket if i take it off and put it right back on maybe a min later?
Old Feb 13, 2009 | 11:56 PM
conan's Avatar
Stock head gasket? How long has it been on the engine?
Old Feb 14, 2009 | 12:19 AM
NBM99SS's Avatar
Yes, if it has been torqued down I wouldn't test it.
Old Feb 14, 2009 | 12:21 AM
im not real sure how long its been on there, didnt have the car before
Old Feb 14, 2009 | 06:16 AM
69_YENKO's Avatar
I wouldn't risk it, you can get a set of new GM gaskets for 40$ from Scoggin Dickey (SDPC)-------------------------------------------->
Old Feb 14, 2009 | 08:39 AM
C-Sicz's Avatar
I would never re-use a head gasket. IMHO
Old Feb 14, 2009 | 02:01 PM
conan's Avatar
If the car has been running for any amount of time on a original head gasket it needs replaced. You'll see part of the gasket will stick to the head part will stick to the block. You'll have to clean both surfaces before reinstalling the head. If you get a multi layer gasket like cometics you can remove the head and reuse the gasket, but there pricy.
Old Feb 14, 2009 | 03:07 PM
Randy@RaginRacin's Avatar
You need a new head gasket.
Old Feb 15, 2009 | 03:11 AM
f-bodyguy's Avatar
wouldnt ever reuse one
