7000-7500rpm shifters come in
who is shifting between those rpms?
can you please list your rocker/lifter/spring combo that you are using?
Is oiling a problem using stock type pump like a melling?
thanks
thanks
I up-shifted my little 346cid na at 7500rpm on a daily bases...
All info in the tread below:
https://ls1tech.com/forums/dynamomet...1rwhp-fti.html
Christian
Shifted at 7k with nothing but PP Gold springs and TFS pushrods on stock 99 rod bolts for over a year when I had the MS3 cam.
Now back to stock cam and pushrods and kept the springs on. Banging rev limiter during tire spin in 1st gear.
I now have a tick. Stock pusrods aa little outmanned by the stiff springs
