broken rev 1116
As for the new springs, I feel confident that the percentage of spring failures will drop from .5% to .1%. I'm not sure if zero failures from tens of thousands of springs is possible, but it is always something we as vendors strive to achieve. Of course once we get the spring issue licked, the cam grinders will come up with more aggressive lobes to push the envelope further.
On another nother note, I just finished prepping a set of heads that had the Comp Cams 918 springs. One was broken. The customer was assured by Comp that the springs were not from the "bad batch" when he purchased them. One thing is for sure, when the single springs break, you almost always have to replace a bent valve
There are some dual spring assemblies made my Comp and Crane that can virtually eliminate failures, but they require machining the spring pads on the heads. They're a larger diameter spring and won't drop in. I haven't tried the Crane drop in duals, but like you I'm not sure I want to switch at this time. Good luck with your decision. Feel free to write or call me with any questions.
Richard
