quick compression question
Old Feb 15, 2009 | 03:11 PM
dragcamaro's Avatar
Default quick compression question
if i was running 9:1 compression on a 6.0 with 74 cc heads, any idea what the compression would be with 64cc chambers?
Old Feb 15, 2009 | 07:38 PM
allngn_c5's Avatar
I'd like to know the formula for this as well.
Old Feb 15, 2009 | 09:06 PM
coanan's Avatar
try this site
http://www.angelfire.com/fl/procrastination/motor.html
Old Feb 16, 2009 | 09:58 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Assuming you were running a .051" gasket to achieve the 9.1:1....with the same .051" gasket in there and 64cc chambers you'd be at 10.0:1 now.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Feb 16, 2009 | 10:50 AM
allngn_c5's Avatar
Thanks for the answer Matt. I tried messing around with a compression calculator and didn't quite get it right. Thanks man. I am sure the OP appreciates it too.
Old Feb 16, 2009 | 09:23 PM
dragcamaro's Avatar
thanks. i have an lq4 im about to build for boost, but ill probably run it NA for a short time while i the turbo build perfected, so i was looking for a little pep while im running it, as i have a set of ls6 heads and the big stockers on the 6 liter
