I think its time for a cam
. What I am missing is a cam, intake, and 3.73s. Its my DD car so I don't want to go too crazy with it but I am hoping for some low 12s / high 11s on the motor. Last time at the track it went 12.85 @ 106 n/a.So first question: if all I ever plan on doing to this car (that I haven't already done) is cam, intake, and 3.73s, do you think its a bad idea to get the cam before the other two mods?
I know the proper cam selection depends greatly upon my stall speed and head flow. Well as far as I am concerned this car will always have stock heads and I love this converter so I don't plan on changing it either. So am I good to select a cam based on that or will it be the "wrong" cam once / if I get the intake and gears?
Next question: I have searched and searched and there is almost TOO much info, I have read the stickies and I think I have a good idea of roughly what I am looking for: something around 220-230 duration and .580-.600 lift, 112-114* LSA. Does that sounds about right or am I reading things wrong?
Next question: I won't ask "What cam should I buy" but I will ask what cam should I not buy? Are there brands or grinds that I should avoid for any reason. eBay knock offs? Used?
Last question: What about stock cams out of other cars? LS2, LS6, LS7? I apologize because I didn't look that up much but will they work, are they worth much of anything performance wise?
Thanks!
i don't think any of the ls2/ls7 cams work...and honestly aren't worth it anyway.
but for what you are looking to get....it would be hard to beat the 224 or 228 cam from TSP.
both are GREAT performers in street applications and are very reliable and make great power across the board.
im running an MTI X1 230/227. the reverse splits work well with stock head setups. they seem to love spray as well and even do better with good heads.
heres a rip from TSPs website and the link if youd like to buy it.
This camshaft features Comp Cams XER lobes! The XER lobes have been proven to make big horsepower & torque thanks to their aggressive ramp rates & healthy lift.
1800-6400 RPM Power Band; This is an excellent performance camshaft with a smooth idle! Custom tuning for automatic cars required
This camshaft typically gains approximately 45-50rwhp!
Ls6 would be fine either way, They dont loose value, and is a great inexpesive upgrade before the cam. So when he is ready to do heads he can sell it basically for what he bought it, and put towards 92 fast
