No Spark or Fire when Turning Over (LS1)
After this, I had spark plugs, wires, air filter, and oil changed.
Now I have another problem. I put a major stereo system in it. (All turns off with a fuse under the hood- Nice Stinger brand one). My battery kept running down. I had a yellow top optima in it and a heavy duty alternator installed. (Don't remember all the specs, but the alternator still does its job when the car cranks). So now the store recommended a Red Top Optima since the other 2 yellows quit while under warranty.
Since I am not "Done" with the car- need one body molding applied, one inner fender, and adjust one fender a little better. And type the 10 page report for highway patrol to get it inspected and make it road legal. So I only crank it about 2 times a month. Fuse is pulled on stereo system. I use no factory wires for it except Head Unit to Factory wiring harness (did not connect the speaker connections as I ran all wires from another amp and RCA's) So no power is being drawn from all this.
Car does not receive power to spark. It will turn over, receives fuel pressure, and the security light isn't lit up. Last time it cranked when they wiggled the cover to the computer. Maybe that was problem, maybe not. It will not crank now. I doubt all the coil packs went out at once. Does anyone have any obvious answers I might be missing? The computer on this car was replaced previously, don't remember why, just remember doing it. I am at my wits end and will be removing all my stereo stuff to send it to an "Auto Electric" shop near me at the end of the week if I can't figure it out. HELP!
PS- I did body work, interior, stereo installation. I can handle basic engine stuff, but my husband and dad do most of the technical stuff in that area. I can't diagnose stuff, but can replace things when I know what is wrong. Now you know what kind of person you are dealing with.
could also be injectors not working. check fuel pressure at the rail and make sure the fuel pump is even running
