ASA cam?
its real nice cam, when i dynoed my car my injector duty cycle was like at 125% or something like that, ill post a vid of when i first put the cam in with a loudmouth 1 and no tune,
Here is my Cam Dyno on possibly slipping stock clutch and stock 241 heads
It never made good power for me. With full bolt on's (minus underdrive pulley) I was at 360rwhp on a mustang.
I ended up pulling it out and swapping it for a pat g custom grind that works much better. Drives smoother and makes more power. Although it doesn't sound quite as mean. The cost difference between the two wasn't nearly as big as I thought it'd be. And in the end ended up costing me more because obviously I couldn't sell the ASA for what I paid for it.
I would not recommend it for most applications.
Just my .02
What was wrong about it streetablility wise? To much lope, and bucking and whatnot in the lower rpm range?
Here is 2 good options with any cam you want even custom grind (5 dollars or so extra for custom)under $700 for each complete kit and you can sell your ls6 springs
http://www.texas-speed.com/shop/item...d=174&catid=49 Cam Kit with Comp 918 (up to .625 lift)
http://www.texas-speed.com/shop/item...d=175&catid=49 Cam Kit with Dual springs (up to .660 lift)
