Budgeting for project, need input
Old Feb 19, 2009 | 10:42 AM
SS Killer's Avatar
Default Budgeting for project, need input
LSX 454ci bottom end
  • Callies Dragon Slayer Crank (4" stroke)
  • Callies Comp Start HD Rods
  • JE Extreme Duty Blower pistons (4.25" bore)
  • Total Seal Stainless ring set,
PRC 237 Heads
  • 237cc Fully CNC Ported Intake Runners
  • 85cc Fully CNC Ported Exhaust Runners
  • Big Bore Chambers Designed For 4.010" Bore+
  • PRC Platinum Spring Kit Rated To .650" Lift
  • 68cc CNC Machined Chambers
  • 2.100" Intake / 1.600" Stainless Valves
  • ARP Head Stud Kit
Valvetrain
  • Harland Sharp Shaft-mounted 1.7:1 Roller Rocker
  • Hydraulic Roller Lifters
  • Chromoly Push-rods
  • (Camshaft TBD)
Forced Induction
Kenne Bell 2.8L or new TVS 2.3L?
Old Feb 19, 2009 | 11:34 AM
conan's Avatar
Is this for the truck in your sig? Also you might want to consider a procharger. The roots type blower gets heat soaked alot quicker then a centrifugal blower. I'm not bashing the KB at all it is a great unit but ask the mustang guys how much power they loose after 2,3,4 back to back pulls on the dyno. How much $$$ is the 454ci moter your looking at?
Old Feb 19, 2009 | 12:12 PM
SS Killer's Avatar
Yea, it's an '01 Silverado 1500 with a 5.3L. I've done a cam and LT's, among other things, but it's time to start planning the big one.
I thought about a centrifugal blower but I'm willing to trade off cooler charge air for a cleaner look (in my opinion). A decent heat exchanger should keep the incoming air cool enough to make some good horsepower.
The shortblock with machining and everything is coming in at a ballpark $6,000. Not bad for an LSX block and all the goodies I mentioned.
Old Feb 19, 2009 | 01:05 PM
Dave 96TA's Avatar
Looks like you're about to put $15k into a $5k truck. Sounds like it'll be a nasty project when it's done though.
Old Feb 19, 2009 | 01:18 PM
conan's Avatar
Sounds good, one thing I would do is call KB and find out if that blower can handle the 454ci, it may not have the cfm.
Old Feb 19, 2009 | 01:30 PM
SS Killer's Avatar
It's a $6k truck, thank you very much! But you're right, it's not 'smart' but it's my truck, you know? I hope to keep it as long as I'm around.
Yea, I know the Magnacharger MP2300 made 950hp on a 434ci LSX. I might go with that one.
Old Feb 19, 2009 | 02:46 PM
conan's Avatar
Thats going to be one fast truck. Is it 4 wheel drive?
Old Feb 19, 2009 | 03:20 PM
SS Killer's Avatar
Nope, 2wd. A 4-link and wider tires will be going in.
